01-11-2014, 04:31 AM
NH
Modern radial tires need less caster but the bias ply Billboards will take about all you can give them. Do your uppers have the threaded sleeve to adjust the arm position/caster? Can you do anything more with that? Are the pads that it mounts to on the frame big enough for a second set of holes behind them?
