Old 01-12-2014, 12:24 PM
dhs.buckley's Avatar
dhs.buckley dhs.buckley is offline
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
normally the problem is the plugs are impossible to get out if someone else has touched them, its a bit bit like oil drain plugs and filters, normally people do them up so tight they just about strip the threads.
luck you got to the plugs early enough, as that could have buggered the threads in the heads.
