Old 01-13-2014, 10:28 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
I run 2.degrees with jag front end .......at 100 on the freeway I can let go the wheel and the car tracks nice and straight........I don't believe you need more caster.....maybe you should look at the rear alignment too.....need a little toe in in the rear to go straight........put the damn sway bar on and put one on the rear too....put some more toe on the front......not caster.........
