Old 02-02-2014, 06:18 AM
patrickt patrickt is offline
Originally Posted by strictlypersonl View Post
Lippy,
When you did the pre-install assembly and inspection, did you check that the input shaft wasn't bottoming out in the pilot bearing?
Lippy, this is a big deal. If your trans shaft is squishing your crank forward, it won't be long until your thrust bearing is adios amigo. It must be checked.
