Old 02-10-2014, 01:10 PM
lippy lippy is offline
Originally Posted by kevins2 View Post
Hi Lippy,
I initially thought my rubber hangers were too short as well. Turns out there is considerable variation regarding where the bottom of the body is trimmed. Mine wrapped around considerably and was preventing the hangers from mounting at the correct angle (the 45 degree corner goes against the floor). After speaking with Doug, I took my Dremel tool and notched the body to allow the hangers to position correctly and that did the trick. As it turned out, that was good practice for enlarging the body opening I mentioned earlier.
Kevin
Kevin, thankfully, one of the few problems I didn't have was interference at the opening in the body. i have a minimum 3/8" clearance, and mostly more. Notching the body is one way to do it, but I managed to get it right using some additional metal hanger material and the sidepipes are now parallel to the body in two planes, so I think I'm all good. Thanks.
