Old 04-03-2002, 01:20 AM
BS12756 BS12756 is offline
Cobra Make, Engine: B&B 351W
I have a B&B with a small block and cut the finder with the body all ready painted, I used a high speed cutting wheel, and finished up with a high speed christmas tree sanding disc, it worked very nice. the trick is make sure tou use a high speed but dont burn it, if the body is not painted yet it will be easy, make sure you give yourself some extra room for the pipes to move (radical cams) mine I had to do over they were hitting at idle.
