Old 04-05-2014, 04:03 PM
patrickt patrickt is offline
The problem with a mount like that is that over time, the solid copper will break due to vibration and chassis flex. Could be one season, could be three, it's not a matter of if, but a matter of when.
By the time that guy vibrates apart, I will long be dead and buried.
OK Patrick - your electrical flunky here. I'm not sure I follow the point of this. My old Corvette doesn't have a neg battery terminal to frame ground and they are notorious for having to ground everything due to the fiberglass body. I don't even have a drivetrain to frame ground on my ERA (but I ordered one from McMasters and intend to install it at the transmission) - and I haven't noticed any issues with grounding. I assume this is just precautionary or have you noticed a problem?
No problems, just tweaking. But if you want to know whether your frame is properly grounded, turn on your lights and fans and put an inductive ammeter around the little black wire that runs from the passenger side cylinder head to the firewall. If it's carrying more than 15 amps, do some additional grounding.
