Old 04-05-2014, 04:22 PM
madmaxx madmaxx is offline
You absolutely want a ground from battery to frame and engine to frame!!!! I welded three transmission shift cables before I figured out what was going on when I forgot to reconnect the ground from the engine to frame. You probably are getting your ground through your motor mounts, if you werent the car would not be running.
