Old 04-19-2014, 02:47 AM
Rossba Rossba is offline
Cobra Make, Engine: DRB, 302 EFI 5 speed 9"
I had problems with my DRB with a windsor not fitting. The engine with the pipes on it was to wide for the engine bay.
The pipes were made by Castle Auto and exhaust in Castlemaine for this engine to fit into the DRB chassis.
Both DRB and Castle Auto said they should fit and stiff **** basically.
I had to cut the side panels out of the tunnel and weld them back on the inside of the chassis.
Coud you fit the engine with pipes, bellhousing and starter together on the bench and install them all together?
Good luck and hope you dont as many head aches with your DRB as me.
Ross
