Old 06-04-2014, 02:39 AM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
I've thought about fitting one. But it doesn't allow you to flash your high beam unless the lights are on. Also, you have to keep hovering your foot above the switch if there is traffic, to constantly change high and low beam. If you have a manual and you are cornering, changing gears, then a car comes around the corner towards you, you are dancing around looking for the switch.
JD
