07-12-2014, 04:15 AM
NH
Yes you can't get a drill under the windscreen to drill the cowl holes so the screen needs removing. The windscreen frame should have the drilled and tapped holes in the bottom center. Usually use a thin strip of rubber between bracket and cowl too.
