Old 07-13-2014, 10:09 PM
Ohio Ken Ohio Ken is offline
Cobra Make, Engine: Classic427 351w
Originally Posted by razerwire View Post
Could part of problem be flex in structure such as seen when going over bump at angle? Or crack in substructure for example. Frame flex?
No it is just the windshield, you can flex it slightly by hand in the middle just enough movement that it shakes when you hit bumps. Yet nice and tight toward the outside edges. It is not loose just a bit annoying on some of these ****ty Ohio roads..
Much better since I read about tire pressures on this forum. Tires had 37psi when I bought the car.mlowered the front to 25 psi and the rear to 27 psi. That really improved the ride and shakes . Might even get better when I install all new bushings in the suspention, and switch to coilovers.
