Old 07-21-2014, 12:13 AM
Tenrocca's Avatar
Tenrocca Tenrocca is offline
Originally Posted by gjkrv8 View Post
For Camber I have a very crude method - I have a square bar attached to a spirit level and I put it against the wheel rim edges and measure how far out the top edge is from the rim for a vertical spirit level etc. I then use a little spreadsheet with a TAN formula in it and I enter the value and it gives me the angle. Its probably not uber accurate but does the job.
As Ben said I made a simple mount to put my phone into and used a level app to measure camber. Have to have a level floor and make sure you have your phone square to the other 2 axis.
Saw the string setup being used at the V8 supercars at homebush a couple of years ago - was virtually identical to what your doing.
