Old 08-24-2014, 02:27 AM
Cobrakiller's Avatar
Cobrakiller Cobrakiller is offline
Just posting this information for any one else using these axles from the VE Commodore. Axles are 32.0 mm (1.180") diameter then step down to 28.5mm, and spline count is 37 at both ends, L/H is 600mm R/H is 566mm. Inner stub is plunging CV and spline count is 32 (fit into ZF diff) Outer stub is fixed CV and spline count is 30 (fit into hub) So it seems that all the race type axles wont fit due to the spline count.
400TT your custom inner stubs sound interesting, what are you using for outer stubs? I am using 30 spline C6 Corvette hubs same spline count/ diameter as VE Commodore 30 spline hubs.
