Old 10-28-2014, 06:36 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by Clois Harlan View Post
Coupe has hit a snag for now (having roll cage completely cut out and properlly fitted) so I need something to work on this winter.
Hi Clois, if you switched from an open plenum to a dual plane, that can make it drivable at low rpm and off idle, reduces the amount of reversion from one cylinder to the other with the higher overlap, etc. It is possible changing to a smaller cam with the dual plane you increase low end hp and could end up with not what you are looking for.
