Old 11-26-2014, 12:58 AM
SPF2948's Avatar
SPF2948 SPF2948 is offline
Cobra Make, Engine: 2010 Superformance; Roush 427 SR
Originally Posted by 601HP View Post
I'd like to get the Z# of that grommet from you.
David
3MRJ8
" Product Description. Rubber Grommet, Oil Resistant, Military Specification, Buna-N/Nitrile Rubber, Inside Dia. (A) 3/8 In, Outside Dia. (B) 3/4 In, Overall Thickness (C) 3/4 In, Panel Thickness (D) 3/8 In, Panel Hole Dia. (E) 9/16 In, AN 931 Number 930-3, Black, Min. Temp. Rating -35 Deg. F, Max. Temp. 225 F, Durometer 50A +/- 5, Elongation 300%, Tensile Strength 870 PSI, Standards ASTM D2000 2BG506, Package Quantity 25 "
25 pieces are about $15 shipped.
For these to fit properly, you'd have to chase the existing pedal holes out to 1/2" (the existing holes are almost there already). The grommet groove needs to be shimmed which could be solved with a washer or some JB Weld or ...
