Old 11-26-2014, 04:09 AM
601HP 601HP is offline
Originally Posted by SPF2948 View Post
3MRJ8
" Product Description. Rubber Grommet, Oil Resistant, Military Specification, Buna-N/Nitrile Rubber, Inside Dia. (A) 3/8 In, Outside Dia. (B) 3/4 In, Overall Thickness (C) 3/4 In, Panel Thickness (D) 3/8 In, Panel Hole Dia. (E) 9/16 In, AN 931 Number 930-3, Black, Min. Temp. Rating -35 Deg. F, Max. Temp. 225 F, Durometer 50A +/- 5, Elongation 300%, Tensile Strength 870 PSI, Standards ASTM D2000 2BG506, Package Quantity 25 "
25 pieces are about $15 shipped.
For these to fit properly, you'd have to chase the existing pedal holes out to 1/2" (the existing holes are almost there already). The grommet groove needs to be shimmed which could be solved with a washer or some JB Weld or ...
My pedals are 1/4" thick, and the existing hole dia. is 1/2". These grommets are a close fit.
Thank you for the info.
David
