Old 11-28-2014, 03:45 AM
Default superdampener
Talos Superdampener makes a dampener to work on an FE crank shaft. It is fluid encased. This is from ATI. Here's the issues I have with it.
When the fluid is cold, takes from 1-3 minutes for the weight to adjust and remove vibrations from the motor. you sometimes get a wicked vibration. I have used the same one for 15 years. After the fluid warms, the weight moves and the vibration stops. You should always allow a motor to warm up before driving or racing alway. This also allows the enging oil to do the same.
Other problem is the bolt pattern on the ATI is for BBC pulleys. Here you have a choice of either drilling out the pulley for BBC bolt pattern or getting a pulley with the correct depth and pattern that clears. I have done the first and now have a BBC crank pulley of 6" on the bottom with a dual belt. I run P/S system on my car. If you have an extra $500.00 ATI will send a guy out to custom match the dampener to the motor for less vibrations. If you google FE dampeners or look on e-bay, there are a couple of after market ones.
Couple of opitions, ASP racing in Texas makes custom pulleys from scratch Ask for Lee. 24 hour turn around. you just need the correct size diameter, bolt pattern, number of grooves depth and inner diameter to have it mount flush and coating of clear or any other color you may want. I got a P/S pulley from him, works great and has 15 years on it of racing. It's one solid made pulley. There is extra meat on it. You can have lightening holes drilled to drop weight. You know about CVF. Iwould think they could also hand your problem. The other thing is have the water pump mounting surfaced machined down to clear the pulley and drill 4 new holes. Watch the depth and make sure the pulley doesn't rub on the water pump housing. I had to trim off a pulley outter groove to clear with march pulleys and water pump snout. Good luck Rick L.
