Old 12-07-2014, 09:37 PM
289FIA's Avatar
289FIA 289FIA is offline
Proud Club Cobra Member
Cobra Make, Engine: ERA 2121
Post Will this work for a mild 302?
First time with Webers. Looking for advice and perhaps some inspiration.
Here's what I have:
IDF 48 (96 vintage)
37 Venturi / Aux Venturi 4.5
60 idle jet
F5 E tube
155 main jet /195 air corrector
50 pump jet / 40 pump exhaust
200 needle valve
Camshaft - Hyd roller
222 intake / 232 exhaust (@.050)
.510 intake / .532 exhaust lift (1.6 rocker)
112 lobe separation
9.8 compression
58cc aluminum heads / 1.94 int / 1.60 exh
What should I expect on the initial fire up?
Any suggestion on jetting or E tubes is hugely appreciated.
Thanks,
289FIA
