Old 12-07-2014, 11:49 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
I'd say if you have a well designed linkage that has all the carbs moving exactly together, then your initial setup should be close enough for a startup, carb synchronization, mixture adjustment, idle speed etc.
FYI, I ran a set of 44 IDFs with a 38 venturi on a 308.
Gary
