Old 12-09-2014, 01:44 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by frankym View Post
one of the things i realized is that if i mount the shoulder harness by going through the fiberglass bulkhead, it would be better to mount the anchor as high as possible. If you were to use the superformance pre drilled holes, you would be mounting about 4 inches lower than you could if you utilized all that space up above the frame rail. I am going to try welding my own mount that will dog leg the anchor point to the center of the seat back and about 1 inch from the upper (underside) of the body panel (that area where the rollbar is in). Then you would be less likely to have that downward pull that the shoulder harness would have under the normal place where SPF suggest to anchor, which is pretty low on the shoulders, like mid to upper back.
Can you post a sketch of your design? If you are doing what I think it won't be structural but I need to see a drawing.
If you have:
+--------------------------ooooo---------+
where + is the anchor point of the cross member to the frame and o is the SPF cut out, and you are proposing doing:
+--ooooo--+
| | <your new work welded to
| | <existing cross
+-------------------------ooooo---------+
The weld will break and even weaken the existing cross. But maybe I'm not understanding what you are proposing.
It might be better if you come through at the upper position, add your welded material but still attach the belt to the lower cross member. Then the forward motion will still probably take out your added work due to the forward motion, but it will absorb some of the energy and at least the belt will still be attached to a structural entity.
Tony
CSX4005LA
