Old 12-11-2014, 11:13 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
I've seen your thread about show your valve covers, and you've probably seen the thread link for another guy with the same issue.
The trouble is the early IDFs had a different pump actuating lever, roller follower like IDA, and would have had no clearance issues.
The linkage became like Dellorto DHLA at some point, probably when they became non-Italian.
The manifold was probably designed for early carbs.
A bit of a problem to come up with a good remedy. A brazed in welch plug might work if you have rocker clearance. You would have to cut the lid off a rocker cover for experimentation.
Gary
