Old 01-03-2015, 09:08 AM
Alloycars Alloycars is offline
Banned
Cobra Make, Engine: Aluminum Alloycars MK5-Roadster 427FE Engine
Here an example of our aluminum body comparing to others. It is still unfinished and came fresh out from the forming sector.
We used an available MKIII body setup for our prototype as we didnt decide for what for model we are going for at this time. The next versions are FFR MKIV based but the way to build those bodies will be the same.
Advantage: As you can see the right or the left side of the car are made from TWO parts only. This means less weldings, less re-finish, less time which results in affordable aluminum bodies independent what for a body style you will use.
