  #357 (permalink)
Old 01-03-2015, 01:51 PM
Buzz's Avatar
Buzz Buzz is offline
Originally Posted by gpete
Originally Posted by Buzz View Post
It was quite clearly stated that the first prototype used a MKIII FFR body complete with perky butt and that a more accurate body is in the works.
I pointed out first the shape.
Post #7
Originally Posted by G-Pete View Post
Looks like (including the perky butt) a Factory 5 Mk. III and they use the same Quick Jacks as FF5.
The response was:
Post#33
Originally Posted by Alloycars View Post
Last year when we found a good opportunity getting an original of 427SC to take some scans. So we started over from scratch and here we are.
....and about 30 posts later they kinda admitted they have used a FF5 body. Pretty much there the Sh!t hit the fan.
Here an example of our aluminum body comparing to others. It is still unfinished and came fresh out from the forming sector.
We used an available MKIII body setup for our prototype as we didnt decide for what for model we are going for at this time. The next versions are FFR MKIV based but the way to build those bodies will be the same.
Advantage: As you can see the right or the left side of the car are made from TWO parts only. This means less weldings, less re-finish, less time which results in affordable aluminum bodies independent what for a body style you will use.
Attachment 24909
This is the information I'm referring to. I have no interest in the 2 way pissing contest. Without knowing for sure - and it really isn't that important to me - I'd prefer to move on from the "Ingo is Tom" bull-hit and melodrama and take Ingo at face value to see whats up with this project.
Tropical Buzz
