Old 01-27-2015, 12:22 AM
Paintwerks Paintwerks is offline
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Originally Posted by Gaz64 View Post
It doesn't cut fuel or spark while traction loss is present. Electronic throttle control from the factory.
Hope you guys can get your systems to talk to each other.
Gary,
Are you talking about the GTS?
If so, then the electronic throttle control is different to the Racelogic system as you suggest. Pulled this excerpt from the Racelogic manual:
".......When the system detects wheelspin above programmed thresholds a fuel cut is initiated to reduce the power of the engine, therefore reducing wheelspin. Connecting the system involves interfacing with the vehicles existing ABS sensors to provide the wheelspeed inputs and breaking each of the signal wires supplying the fuel injectors. This allows the Traction Control to cut fuel when wheelspin has been detected.
Do you think there'd be an issue with the Racelogic TCS initiating a fuel cut? I'll check that out with ChipTorque.
www.paintwerks.com.au
