Old 01-27-2015, 10:43 AM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Dan,
When I wired my car initially, not everything worked properly and I discovered that two pins (one on each connector) on the wire harness were not seated properly. So, when I connected them, the pin simply backed out of the connector and wasn't making a connection. It is really easy to check if you haven't already. In my case, as I was checking all the connections, I heard the two distinctive "clicks" as the pins locked into place. I think it is best to check these connections with the connectors unplugged. My apologies if this has already been addressed - this has become quite a long thread!
Good luck tracking this down.
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
