Old 01-27-2015, 11:40 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Sorry lads, I stand corrected.
The ECM retards the ignition and drops injectors.
Traction Control System
When drive wheel slip is noted while the brake is not applied, the electronic brake control module will enter traction control mode.
First, the electronic brake control module requests the engine control module to reduce the amount of torque to the drive wheels via the serial data. The engine control module reduces torque to the drive wheels by retarding spark timing and turning off fuel injectors. The engine control module reports the amount of torque delivered to the drive wheels via the serial data circuit.
So it would seem that you would need an ECM. a BCM, and an EBCM.
Sounds too complex. Would be easier to add the system described by Sime above.
Gary
