Old 03-21-2015, 04:20 AM
renovationinnov's Avatar
renovationinnov renovationinnov is offline
Cobra Make, Engine: venom motorsports /ls1 auto
Default fuel sender leak
help or advice needed
I have a VDO fuel sender in my tank but I have had 4 rubber gaskets turn to goop [ rubber just melted ]
so next I rang vdo supplier whom told me that it shouldn't happen & I must be using racing fuel [ no way just pump unleaded
so I have tried direct stick with threebond leaked
so cleaned & used stag
leaked thru the threads only so now
its to ask for any ideas as the tank is alloy & the gauge is as per manufactures fitment instruction
it only leaks when you fill it up til it gets down
I have checked if I have pressure build up ................no so its just load pressure leak
any ideas to seal .................& yes the wife said already don't fill it to the top
but the leak is a weep only but still a leak
ANY HELP PLEASE
ROB
not all your babies are your children
