Old 04-28-2015, 06:48 AM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Against ERA's recommendations, I'm running 27 inch tall 70 series tires on my front and when first set up my left one rubbed a little on the bottom of the lip where it is rolled under. I ground a little on the lip to angle the inside edge back a little and just barely cleared. But by the time I set the suspension height and aligned the front, I ended up with good clearance. It's not noticeable.
Is this the same place yours is rubbing - at the lower roll under for the rocker panel? Can you just grind the edge of the lip back slightly, contour it and touch up the edge with some paint? I think the body update came between our cars so mine may be slightly different in that area.
Here was the bottom of my fender lip showing the contact before I did some grinding.
No Dan, not even close. I am 5" above your location (see pics I just took).
I also have a little damage to the Pass side, but nothing like this.
I am running BFG 235/60R15. I believe this is what is called out for by ERA.
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
