Old 05-16-2015, 11:44 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
FYI
If you do not have a good ground between the engine and the chassis and chassis to the battery the electrical current will create its own ground path, this is not a good for your mechanical components! The current will travel through whatever means possible to get back to the battery and completing the circuit. The current can travel through bearings and races, gears, etc. and cause pitting and ultimately failure in those components.
