Old 05-20-2015, 06:54 AM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
I replaced the rear brake pads on mine it was painful with the rearend out. I am sure it can be done, but it is time consuming and even with the rear and tunnel out it is not easy to do. Since I was dropping the rearend to replaces a shaft seal, and the gear lube soaked brakes it was much more doable with the rearend out. I have done that twice now.
ERA has the replacment Jag Girling brake pads and they are not cheap but do work well.
Phil
