Old 05-22-2015, 07:05 AM
ZOERA-SC7XX's Avatar
ZOERA-SC7XX ZOERA-SC7XX is offline
It sounds like your biggest issue here is the pinion seal leak. You have to address this eventually, sooner rather than later. The rear end comes out of the car really easy (I installed mine with a floor jack and my GF and daughter on each end to steady it). Once the rear is down and out you can have the seal replaced and change out the pads with stock Jag pads...really inexpensive online. As for the shifter, talk to Doug and get his ideas. Good luck.
