Old 05-28-2015, 09:08 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
Originally Posted by mdross1 View Post
Just what I need Mark a little more fodder to whet the whistle. For now plan is to polish all the engine aluminum and roller cam change. If not quite enough then by all means will look into the Chris Alston drive system that looks as if it could be made to work. Might even call for dimensions.
Thank you all again.
Mike
My current car has a 427.....I will probably stick with a small block but give it a bit more punch next go around. Speaking of the 385 series I think that it would be an awesome motor punched out to 550+ or whatever size. For a street car running a big hydraulic roller it would be a great street cruiser but I still think it would be insane on tires and just trying to remotely hook it up without some super sticky rears and the right suspension. I just got rid of a gem of an 03 cobra with a stock motor with a KB2.6 twin screw running just 16lb making 575hp/575tq at the wheels. The torque was literally at 500+rwtq at 2000rpm and up. It sounds really fun but I think it would be pretty treacherous. When I was thinking of my first cobra I kept thinking I would go the coyote route but now after I've had the 427 I really enjoy it. In the future I could see having a second cobra with a mod setup.....they are easy to modify and produce insane power if that's what your into.
