Old 07-21-2015, 02:39 AM
PeterAllen's Avatar
PeterAllen PeterAllen is offline
Cobra Make, Engine: Puckett 250 GTO - LS1
Default Advice on a mechanical parking brake that works?
I’ve installed the Wilwood spot mechanical parking callipers but it appears they simply aren’t up to the job required. I’ve reworked, reworked and reworked cables, levers, pull rods, etc, etc, but they will not hold the car with the engine on idle and 1st gear engaged.
Today I maximised all the adjustment so the calliper was in the full ‘on’ position. I then managed to pull the cabin handle up just two clicks. As much force as could possibly be applied was.
I started the car, let it idle, engaged 1st and slowly let the clutch out. The car moved off with little or no resistance.
Can anyone recommend a stand-alone mechanical parking brake that works!
