Old 08-10-2015, 04:03 AM
xb-60's Avatar
xb-60 xb-60 is offline
Originally Posted by mdross1 View Post
Sure do see the 427 Cobra cues in this car. Back in the day also considered doing a V8 swap into an MG till I discovered the fiberglass replica kits. Also back then looked at a small block Cobra that had been driven year round up here in the Northeast. Seeing the aluminum to frame interface severe corrosion along the frame rails sure was a wakeup call. It was then that I learned how bad is was to have aluminum and steel together.
It's surprising how many people still think "aluminium....it doesn't rust" Well no, it doesn't, but it sure does corrode!
If you have a small amount of steel in contact with a large mass of aluminium...all is probably OK, but reverse that, and your small amount of aluminium is a fast corroding sacrificial anode! The difference in their potential difference is quite large. Make that magnesium and steel, and stand back and watch the Mg disappear!
Glen
