  #31 (permalink)
Old 08-25-2015, 06:20 PM
xb-60's Avatar
xb-60 xb-60 is offline
If you are putting a new clutch and flywheel in it's worth getting the flywheel and pressure plate balanced. I sourced clutch and flywheel from different sources. With the pressure plate located on the standard dowels it was way out of balance (according to the shop I got to balance them). The guy reckoned it wanted to fling itself off their machine.
Good point Mike (and Berninca).
For starters, the clutch and flywheel I settle on will be branded the same and from the same supplier; that seems a no-brainer. Balancing the two together should be easy and relatively cheap.
Glen
