Old 09-01-2015, 06:16 PM
huskersnake huskersnake is offline
Cobra Make, Engine: Hurricane, 427/451 Side Oiler
Send a message via AIM to huskersnake Send a message via MSN to huskersnake Send a message via Yahoo to huskersnake
Default Started with 4.25" cylinder bore and no ridges.
RICK LAKE,
I purchase this as a bare block with no other parts except front and rear mains caps and bolts, center main caps with bolts, side bolts and spacers with L/R markings, rear three bolt cam shaft end cap, screw in hex head freeze plugs and oil pressure relief valve installed in the galley. As far as a crank with numbers, I can't provide that information. The installed crank is aftermarket. The seller indicated the block had previously been in CSX3337, but was removed to install the original block purchased by the owner of the car. With limited success, I have only been able to find a few pictures of what I believe is CSX3337. No history of engine work.
We plan on installing hydro rollers.
I do appreciate the build tips on the oiling system. I have attached a picture of the short block as it is today.
