Thread: Bad Starter
Old 09-06-2015, 09:43 PM
Dominik's Avatar
Dominik Dominik is offline
You might want to connect a cable direct from the negative battery terminal to the starter. This is a place where I don't save weight. I use 50 square welder cable. Not sure how that converts into gauge thickness in the US of A.
To check for losses, use a jumper cable - also with a decent area/cable size ("Diesel" engine jumper cable) from your Battery to starter.
If I don't respond anymore, that's because I can't log in
