Thread: Bad Starter
Old 09-07-2015, 09:13 PM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
That strap was a supplemental ground that was in addition to the black ERA ground wire. Yes, I turned on my lights and fans and then measured the current running through that wire and it seemed a bit high. You can not just disconnect the wire and run it in series with your multimeter unless you have a very special multimeter that will measure higher amperage. Most multimeters can only measure very tiny amounts of current that way.
That braided strap had to have two different ends. The one for the firewall is only 1/4', the manifold bolts are way bigger requiring a bigger eyelet. Do you recall where you got the cable?. I see a lot of companies sell cables in bulk, but I cant find much info on putting on your own custom terminals.
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
