Old 09-16-2015, 07:41 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
That sucks!! When I first got my Cobra the clutch went on day 3. As far as your Tremec goes you might try and contact Tremec and see if there is tech support that might be able to help you. It sounds like the shifter has come disconnected from the shift rod. If you are up to it you might remove the shifter and see what's up down in there. It unbolts from the top of the trans so you can choose what shifter location works best. Check out the website too there might be some good info for you. Good luck.
John
