Old 09-30-2015, 06:23 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Originally Posted by scottj View Post
We kept going stiffer on spring rates for the track. Eventually the chassis began to behave like a kart chassis. This resulted in pinching the passenger door in the body opening and splitting the inner to outer door panels. That's quite a bit of chassis flex...
Compared to any race car or current high performance production car standard these chassis are wet noodles.
Scott
I agree with you regarding all of these short wheel base Cobra's.....
That's why we spent all of the time developing the chassis on KMP259. Our chassis is built to reduce the torsional twist from the suspension input. After we enhanced the chassis.....the bottom plate bolted to the frame rails from the front of the chassis to the rear of the chassis was the icing on the cake. On the track we could raise or lower the chassis one turn on a corner and see the results in the tire temps immediately ......
The national championship cars we built over the years, all started with a well thought out chassis first..... Then on to the suspension.....
Morris
Morris
