Thread: Fuel Pump
Old 10-07-2015, 07:54 AM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
-drill and tap frame to accept mounting bracket that comes with pump.
-the in and out line openings on pump are located on the same end so you will have a direct connection to the in but the out will need a u shaped connector to get you in the forward direction from the out line of pump back to main fuel line along frame.
