I got mine on today. Really cleans up the lights. I never noticed how sloppy the gaps were. My only suggestion for improvement might be a even thicker piece of rubber as some gaps are more than others. GREAT IDEA !!! THANKS jimbo01 !!!
This is how I did it... Took about 30'minutes
1. Unplug lights (white connectors)
2. Remove plastic lens (I did this to get at bolt head to remove and install 7mm nuts easier)
3. Remove 3 - 7mm nuts from rear of each each housing
4. Pull out housing and unconnected wire
5. Put rubber grommet on light housing and re-install
6. Tighten 7mm nuts ( use flat head on bolt head to get solid tight fit)
7. Re-install lens
8. Plug in connectors ( I did one at a time to ensure right plugs were connected)
9. Test all lights
ASO544
