Old 11-14-2015, 01:53 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
I still think there has been a break in communication somewhere. I know that Eric has a chassis dyno there, and to me, there would be little reason to pull (20) Roush 427R's out of the crate and put them on an engine dyno before installing them into Cobras.
My gut tells me that the info that has been provided above has all been chassis dyno stuff, which opens a whole other can of worms, and a whole other can of variables.
Would like to see the dyno sheet.
Actually, not many variables.
The dyno sheet I looked at were chassis dyno's. Eric told me he was impressed how good my engine ran. Mine had 10.5:1 CR. Eric told me the chassis dyno incorporated the upgraded side pipes, that I had him install on my car, as were installed on the ? superformance cobra's he also had dyno'd. He showed me the dyno sheets, and per him, it was apples to apples.
Believe what you want to believe.
Here is the dyno sheet eric gave me, of the best running roush 427R he had dyno tuned.
chassis dyno Roush 427R - Club Cobra Photo Gallery
Here is the dyno sheet of my engine, stock stroke ford FE 427 Hi-Riser heads, 10.5:1 CR, Holley 780 vac, 1964 factory Ford dual plane intake.
Chassis Dyno - Last Run 427 High Riser - Club Cobra Photo Gallery
Let's see, my engine made 40 more hp, and 50 more ft-lbs torque, not that it really matters.
Let me guess, you still don't believe me.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
