Old 01-02-2016, 06:45 PM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Originally Posted by MikeFromPerth View Post
boil the kettle and pour it over the sender maybe?
Slowy, common problem is if its a single wire sender then the body of the sender is not earthing properly on the engine/head block etc. This could be due to thread tape on the threads of the sender.
If its dual wire then measure the resistance between the wires and see if it changes when you do a heat test.
Gregg
