Old 02-05-2016, 05:55 PM
cobrakiwi's Avatar
cobrakiwi cobrakiwi is offline
Cobra Make, Engine: Coombe, Shelby Block 496
Craig
Did you center the hole?
It is supposed to be offset inch to right.
Hey Jeff,
yes I did center the hole, I also make the opening a little wider as well, my thinking, more cold air in when driving, more hot air out when stopped.
I also always try and run the ford sidewinder intake, that pulls the carburetor back close to center.
Even with a center carburetor setup the small air cleaner and turkey pan will sit under the cut out.
Turkey pan is plenty wide enough to catch the cut out.
Thanks for keeping me straight
