Thread: Slave cylinder
Old 02-10-2016, 07:39 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Originally Posted by twobjshelbys View Post
Yes, you need to get better alignment on the rod. Lengthening it helps but I can tell you from experience that the misalignment will result in premature wear of the gasket and it will leak.
I'll second this comment. Happened to me as the clutch pedal bled down while shifting on I75 mid-day. Since then, aligned rod better and used hardened steel ( no flex ).
