Old 02-26-2016, 08:31 AM
strictlypersonl strictlypersonl is offline
You can probably get away without lubing the sway bar bushings if you don't drive in inclement weather.
I recommend that you periodically use spray-grease on the damper end with the spherical bearing, especially if you drive in a dusty environment. It hasn't happened often, but I've seen the bearings deteriorate pretty badly in old (>20 years) cars.
