Old 05-08-2002, 10:20 AM
Whaler Whaler is offline
Default Question for those who used painless...
Did you guys only have a horn relay in the set?
I am starting to dig in and looks like mine only has a relay for the horn, and nothing for the lights.
My painless wiring harness was somewhat partially installed and wiring roughed in by the builder so I am discovering this only now. Also I have the instruction and pictographs that include the GM lightswitch...thats no use to me as I planned on putting everything on toggles.
Does a GM headlamp switch incorporate a relay or something to handle the higher current??
I have plans on the park and head lamps on a Lucas 2 position toggle. Will also incorporate the gauge dash lamps into the park lamp cct as well. Have to figure out a hidden rheostat for dimming them to where I like them then leave it alone.
Just thought I would ask....
where do I tie in for a push button start in conjunction with a normal ignition switch uses acc- off- on- ignition.
I guess I wire into the last postion to those applicable terminals...correct?
