Old 02-27-2016, 11:05 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by cycleguy55 View Post
What size would you recommend for mounting on the rear bulkhead, between the seats? Any other recommendations or suggestions?
3 liter system with bottle mounted in the trunk. Actuator only to be mounted in the passenger compartment, along with at least one of the three nozzles. 1 nozzle in the engine compartment on the firewall pointed towards the top of the engine and fuel supply, one mounted at the rear where the fuel supply leaves the tank.
This is pretty cool too for engine bay. Just don't know where I would put the bottle!
MS Pull Cold Fire Super System | NON-Toxic Custom Manual Fire Suppression Unit
Bottle (3 liter) is mounted in the trunk. Actuator handle needs to be installed in an area readily accessible from the drivers seat with you full strapped in. Unless you are going with an automatic set up (it is my understanding it uses a temp sensitive, burn through actuator in the engine compartment), if you cannot reach the handle, then it is useless.
Bill S.
